Configure aggregate routes so that the router advertises a single route (aggregate route) that represents all destinations. Aggregate routes also reduce the size of routing tables.
  • Disable BGP before you enable aggregation.
  • You need the appropriate aggregate address and mask.
  • If required, policies exist.
  • You configure BGP on a VRF instance the same way you configure the GlobalRouter, except that you must use VRF Router Configuration mode and the prefix ip bgp. The VRF must have an RP Trigger of BGP.
    Route refresh is not currently supported on non-default VRFs.
  1. Enter BGP Router Configuration mode:
    enable
    configure terminal
    router bgp
  2. Enable BGP aggregation:
    bgp aggregation enable
  3. Add an aggregate route to the routing table:
    aggregate-address WORD<1–256> {advertise-map WORD<0–1536>] [as-set] [attribute-map WORD<0–1536>] [summary-only] [suppress-map WORD<0–1536>]
  4. Exit to Global Configuration mode:
    exit
  5. Enable BGP:
    router bgp [<0-65535>] [enable]
Switch(router-bgp)# aggregate-address 2001:DB8::/32 advertise-map map1 attribute-map map2
Enable BGP:
Switch(router-bgp)# router bgp 4 enable
The following table defines parameters for the aggregate-address command.
Variable
Value
advertise-map WORD<0-1536>
Specifies the route map name for route advertisements.
as-set
Enables autonomous system information. The default value is disable.
attribute-map WORD<0-1536>
Specifies the route map name.
WORD <1–256>
Specifies an IP address and its length in the appropriate form. The value must be entered in the format a.b.c.d/len or ipv6addr/len.
summary-only
Enables the summarization of routes not included in routing updates. This variable creates the aggregate route and suppresses advertisements of more specific routes to all neighbors. The default value is disable.
suppress-map WORD<0-1536>
Specifies the route map name for the suppressed route list.
The following table defines parameters for the router bgp command.
Variable
Value
<0-65535>
Specifies the AS number. You cannot enable BGP until you change the local AS to a value other than 0.
enable
Enables BGP on the router.
